a_kelley
mechanical fixer
- Jan 26, 2010
- Rutherfordton
Thread to post up your weird, crazy, no way possible noises/actions/faults/failures.
4.0 Jeep engine - rotational steel on aluminum cyclic, constant screech/warble - checked starter, TC bolts, cracked flex plate.. no. Distributor shaft was the source.
Dodge omni. - key off position, hazard lights on, turn signal on, and wipers on. The radio, wipers & lights would turn on and off with the hazard lights - from the factory - all factory wiring. It was a factory wiring bug.
98 zj - no o2 codes, only a bank 1 lean - yielded mid single digit fuel mileage. Unplugged o2, reset ecu, instantly doubled fuel mileage. Still hadn't changed the O2 on it.
More if I can remember them....
What's your mechanical/electrical/automotive WTF!? Story?
