Metal Fabrication/Machine Shop Auction
jeepcj3a
winston salem
*Came across this listing and thought some here would be interested. No association with any of the parties involved”*
Current Auctions - Country boys
Nov 13, 2019
This auction is of a very well equipped metal fabrication shop located just oustide of Farmville, NC at 4658 Hwy 258 between Farmville and Fountain. This shop was meticulously equipped and maintained to say the least. Lathes, milling machines, specialty equipment, welders, fabrication equipment, press brake, and tons of measuremnt tools, tooling, and much more.
The auction will be held live on location as well as having online bidding on some of the larger items. Auction preview dates and times will be posted here.
INSPECTION Friday November 8th 10 AM to 2 PM
EQUIPMENT LIST
WYSONG PRESS BRAKE MT5-1131 S/N MTH100-144
DOOSAN CNC LATHE LYNX-220L S/N ML0022-005258
LAGUN 717-S Milling Machine w/Lagunmatic & Dynapath Delta CNC control
(1997) 5HP S/N 40580
LAGUN FTV-2 Milling Machine LAGUNMATIC CNC FTV-2 S/N 41885
SUMMIT LATHE 16"X80" S/N 2000-32711
HENDEY LATHE
DOALL VERTICAL SAW 2013-V S/N 500-982892
DOALL HORIZONTAL SAW C-916
CLEEREMAN DRILL PRESS w/X & Y TABLE
UNKNOWN MILLING MACHINE
ROLLS MECHANICAL 48"X10GA
DAKE 1-1/2B ARBOR PRESS
FAMCO ARBOR PRESS
BROWN & SHARPE SURFACE GRINDER
BALDOR BENCH BUFFER W/ STAND 333B P5-96
BALDOR BENCH GRINDER W/ STAND 8107WD P885
WILTON BELT AND DISC SANDER 4202A 8129
MILLER DELTAWELD 451 w/70 SERIES WIREFEEDER S-74DX S/N KA818458
MILLER AEROWELD HYBRAD ARC S/N KG106732
MILLER SYNCOWAVE 350 JK635996
MILLER INVISION 456MP w/70 SERIES WIREFEEDER S-74DX
MILLER SPOTWELDER LMSW-52T S/N KK036289
MILLERMATIC 135 WIRE WELDER #907019 S/N LC516240
AIRCO WELDER w/MILLERMATIC S-52E WIRE FEEDER & MK PRODUCTS
PULSE CONTROL MODEL 158-001 (SN 0614) CV 450
MK PRODUCTS COBRAMATIC MK-3A
MILLER SPECTRUM 1500 DC PLASMA CUTTER
ACRON WELDING TABLE (2)
STERLING DRILL GRINDER
CLAUSING VARIABLE DRILL PRESS 2274 S/N 5240921
RIGID 535 PIPE THREADING MACHINE & DIES S/N 391119
TOOLING AND RACK
METAL RACK AND SHEET METAL
METAL RACK AND METAL SHAPES
WELDING TOOLING & CLAMPS
HAND TOOLS AND ACCESSORIS
ELECTICAL TOOL ING AND SUPPLIES
DRILL BITS, END MILLS AND CUTTERS
PRECISION TOOLS AND ACCESSORIES
STEEL WELDING TABLES
JIB CRANE
CHAIN HOIST
LIFTING MAGNET
POLE RACK TURNERS
