userbmx1315
builds more then wheels
- Feb 8, 2008
- Bessemer City, NC
I can get seamless 1025 thru work. Most people use DOM for cages, how does think compare to DOM?
no its not pipe...
true seamless is more expensive. Its actually called CDS (cold drawn steel). The hole in the center is "punched" through a solid bar. If this seamless tube is not drawn over a mandrel, tolerances may not be that great.
DOM is simply a process (seamless is also "DOM"). However, its commonly referred to ERW tube that has been drawn over a mandrel to remove the weld seam and work the tube to pretty tight tolerances.
"DOM" ERW tube is popular for tubing that requires thin walls. For tubing that requires thicker walls, the "seamless" type tends to be advantageous.
1020 vs 1026 doesn't have a ton of differences. If you are using it for tube for a crawler, whatever is priced in your budget should work fine, so long as you don't plan to race it 200mph or fly to the moon in it...
You should have no problem getting a quote, but it might be difficult to afford.It was for xj savage. My quote guy got me a quote for this, it being like $3.5 a foot. But hes going to go with dom. Ima try to get a quote from EMJ in charlotte.
