Metric equilivant to 9/16 lugnut
Franklin
Hickory NC
Wheel spacers are metric and I cant find my conversion tables. 9/16 lugnut goes on about 2.5 turns then lock so it is real close. Any help will be appreciated. Also where in the hell can I find a metric that large?
The advance auto here has a ton of sae and metric lugnuts. If yours dont, napa most certainly will.
I had to change out my metric lugnuts on my old tahoe, i actually had to get them from just tires. They werent the cheapest there but they had them in stock.
9/16 as in fits a bolt that is 9/16, or as in takes a 9/16 socket?
9/16 stud thread size. Going to a tire shop to play with their nuts :flipoff2:
ok so standard for that is a 7/8 nut which i think is a 22mm
good luck.
14mm 1.5" closed end lug nut is correct
