Midnight Dakota SAS
sqrl$$
Lexington
Doing a SAS to a Dakota for a customer. Using a D44 from a full-size Bronco, radius arms and ZJ coils. He is keeping stock rear axle because of the speed sensor and using spacer/adapters to change to the 5 on 5.5 lug to match the front pattern and width.
Cut out the stock IFS garbage:
Locating axle and plating frame to mount coil bucket and shock mount:
Went through axle and put new bearings, ball joints, u-joints, brakes, calipers and rotors
Sitting at ride height. I rolled it outside to get some pics and see the stance.
That looks awesome!! I've wanted to do something like this for quite a while. I think these trucks are under rated. I did the same thing on a xj but sleeved the radius arms with 2" .250 wall DOM and put currie johnny joints on the end. They flex much better than most people think.
Still have to build a set of rock sliders so he can get in and out and protect the rockers if he gets offroad with it. I am still going to have to put just a little more lift in the rear, he wants to do add-a-leaves to beef up the rear spring packs.
