raleighjeepguy
- May 27, 2007
- Raleigh,nc
Draining your tcase and then realizing the PO stripped out the filler plug! I really wanna kick myself in the a$$ for this one!
Depends on the process you plan on using.Am I going to have probs with that alum case welding a nut on?
Yeah, what the hell was I thinking? I'll bet the plug was/is steel, threaded into the alum case. There's no way you can weld a steel nut to the alum case to serve as threads for the plug. I think the only option other than an oversized plug is to tap the hole for a bigger plug. That's quite the fubar.I would think the fill plug is steel, not aluminum, so you should be fine.
If the plug is aluminum, either TIG, or alum wire mig it.
Actually this reminds me of something...
where can you find differential drain plugs that use a hex (allan) or square (3/8" drive) insert to remove them? E,g, plug is female so when the corners get rounded off on rocks you can still remove it? Need one for Yotas.
I don't believe Ive ever felt so retarded in my life....
You mean like the ones that are shown with the large diff armor?
http://www.trail-gear.com/trail-armor.html
I don't think I'd feel as retarded as the PO that stripped it. HOW THE HELL to you strip the fill plug? You don't tighten them that much!
As for fixing, yes that fill plug will be steel. Find a bolt that the head fits in the hole. Stick the head in the hole and weld around the shaft of the bolt of the bolt. then thread a couple nuts on the bolt and extract the fill plug by wrenching on the first nut you put on the bolt.
Pull the speedo gear and fill thru that hole.
Be real careful with this.If the fill plug is stripped and not the threads, then if you get an EZ-Out in it. I would think that would work. You might have to drill on it a little to make a smaller hole for the exstractor to fit.
