Tom@Hilltop_Machine
- Mar 31, 2005
- Rural Retreat, VA
And to think that all of those cabinets of info easily fit on the smallest of flash drives now.
Guess I'm old, had to look up DTF
I knew what DTF was, but I agree on the blue and purple. I would assume DTF could turn into feelings where Single AF means they want to stay that way. I dont know. I've been married 21 years.Guess I'm old, had to look up DTF
And now I don't understand the difference between purple and blue
27 here, which is why we're both probably also DTF.I dont know. I've been married 21 years.
Direct To Film; it’s a printing process used namely for applying prints to garments.27 here, which is why we're both probably also DTF.
Man, these AI memes are really starting to take the fun out of this thread.....All I see is an attempt at rendering a 70 SS Chevelle with some bastardized Buick headlight trim....I can only assume that engine either sheared the crankshaft off at the balancer or was reassembled without a crankshaft for fit-up?
Damn v10Tell me whats going on with the exhaust ports
Probably why the crank centerline is so deep in the block....but then it is probably a modern V10 swap, which will definitely have some 10mm bolts on it....Meme 100% derailedDamn v10
That’s the world industries Motown motor with sbc block that uses hellcat heads with classic ford valve covers, duhTell me whats going on with the exhaust ports
Does the hell cat have that rail below the exhaust ports and apparently roller rockers for alignment dowelsThat’s the world industries Motown motor with sbc block that uses hellcat heads with classic ford valve covers, duh
It has big square ports like pictured, complete mashup in that picDoes the hell cat have that rail below the exhaust ports and apparently roller rockers for alignment dowels
