Motobilt Wheel Rock Rings
motobilt
Dothan, AL
Motobilt Wheel rock rings click here!
Motobilt has created a wheel reinforcing rock ring for the 17" Method Standard wheel. The ring uses the existing bolt holes in the simulated beadlock wheel to bolt onto the outside of the wheel to protect the wheel from scratching or being hit on rocks. It also gives the otherwise "standard" wheel a unique outer ring to set your wheels apart from others. Ring may be painted to match or a painted/ powder coated a coordinating color of your choice. You will need to use longer bolts (not included) when attaching the ring to the wheel. Ring is cut from 3/16" steel and shipped raw metal.
