Motor Not Starting
83ChevyK10
Kings Mountain,NC
Ok, so did a motor swap for my new wheeling truck. Motor I pulled ran fine when pulled and now I'm getting no spark. Turns over, gets fuel but wont run. Any suggestions to what I can do to check or fix this problem.
Did you swap the coil with the engine? If you used the one already in the truck maybe it is bad? What about the ground, block to frame, is it connected? I will edit as I think of anything, just trying to come up with stuff that is kinda obvious but can easily be overlooked.
