TRC&P25
New Member
- Jul 6, 2008
- kannapolis
putting my 22r back togther from a full rebuild, pistons, rings, crawler cam etc, whats the best oil to run. I ran havoline in it before but i wanted see what yall run in your motors, thanks!
Rotella. It wont build up the sludge, thats why it's recomended for diesel engines. Like Voodoo said for hammering it on the trails you need a heavier oil.
I've worked on mercedes and BMWs since the late 80's. The cars that had the oil changed religiously at 5k or less will keep going and going. The cars I see that have followed the 10k-15k oil change intervals look like total shit under the valve cover (@100k plus miles) and usually have oil consumption problems much sooner than the 5k and below serviced cars. The crankcase vent valves on the V8 BMWs like to stop up around 100k with longer service intervals. I've had the benefit of servicing cars from the time they were close to new until they had 300-500k on them and have seen the differences in service schedules and the effect in the long run. But to answer your question:...I run 50 wieght Valvoline XRC race oil in mine and change it after 3-4 weekends of riding. I know it's overkill ,but changing oil is cheap in the long run. It also gets beat every time it's taken out.As a professional technician, I vote you run what you want. Just change it every so often, though it doesn't need to be anywhere near as often as 3000 miles. That's a waste of money. Every 5 or so on conventional and closer to 10 on synthetic. BMW runs 15-18k on Castrol Syntec and we have very few engine problems due to oiling issues. On your rebuild I'd change it at the first 1500 or so after initial break in.
