motor swap need help
vernon
Virginia
okay i have a 78 350 and a 90 k5 witch is fuel injected can i put the 90 heads and intake on the 78 block and run the fuel injectinthe 90 has a 700 r4 witch will bolt up to a 350:driver:
#1 Run off the witch, she will turn our rig into a frog.
#2 Yes you can put the TBI on the 78 motor. You will need the Heads and intake (not necessarily the heads, but he has them and that will be simpler) distributor, ECM, and the sensors. You will either have to use all the inputs or get your ecm reflashed to remove the unused ones.
It is a GREAT swap for driveability, but a little more cocmplicated than bolt on and go.
thank you for helping me and dan on this i would like to use the heads of the vette motor they are big valves in theme if it was me i would use the hei and a carb but he want the fuelinjection like i said thank you
