Moulding Adhesive Removal
Any thing with D-limonene in it will work or the 3M wheel will work
I have used almost all chemicals and also have the eraser wheel and have found the eraser wheel to be the most effective. If it's thick adhesive you may have to wipe it down with some adhesive remover afterwards. I prefer to 3m adhesive remover
The 3m stuff is good and goo off is a close second. Lowest has goo off in large cans if needed.
Sent from my Kindle Fire using Tapatalk 2
Eraser wheel all the way. Once you get one you will wonder why you didn't get one sooner. I don't remember then being all that expensive.
Thanks all for the ideas.... Was using goo off and was working decent, but was indoors and found out quick that's something to use outdoors.
