marvilusone
- Oct 21, 2007
- Charleston, SC
I need 2" more stretch in the back of my XJ. Can I drill new center pin holes and slide everything back? I would keep the original pin in there as well and just drill a second hole in the perch and plate. I'm using 7" long perches. I'm just trying to avoid having to trim into the rear door jamb and have alot of sheet metal to patch.
I'd redrill the perches first, I have used that method several times to get and extra 1" or more. If that isn't enough you could redrill the leaf pack. Works best if you have a drill press, good bits and take the packs apart and do single leafs, but...I have done the whole pack at one time before, just harder on the bits.
