Moving a Cable modem to another room
hans747
Asheville, NC
Hi folks!
When we got set up to receive cable internet, I asked the installer to put the live cable in our basement because that was closest to my home office (I telecommute, so having fast internet at my computer is part of my business). But its location leaves the living room upstair in sort of a dark spot, signalwise. I have thought about moving the cable modem to one of the empty wall jacks in a room directly above my office.
Now here's my problem:
I have identified which line in my cable box (outside) leads to the desired room. I connected that cable to the incoming signal line that comes from the street. But I cannot get the modem to connect to the internet when I plug it into the new wall jack. It gets about halfway through the boot-up process and then stalls out. The people from Charter tell me that I need to have a guy come out and set it up. It's not expensive, but i really don't want to have to reschedule an entire day (say it with me: "between the hours of 8 am and 2 pm") if this is something I can fix myself.
My questions:
I am wondering if coax cable requires some special connectors to run data? Right now, my wall jack uses those cheesey bottom-shelf-grade plates that look like this. Would better hardware fix my problem? Or is there something else that I'm missing? Or do i just need to punt a call in the pros?
There's nothing special about data wire, aide from the fact that you want it to be RG6 instead of the older RG59 so it has good throughput. Are you sure that the wire you think it is outside the house is actually a continuous wire? E.g. have you somehow verified signal continuity? If you have cable TV, you could verify by plugging a TV into it.
As mentioned though, the easiest route here is just to get a repeater.
Make sure there is not a splitter on the line that you're moving it to, you may be over-attenuating the signal if you do. Other than that there is no magic if the other cable line is fully functional.
There's no reason to mess around with a repeater, this should be a very easy problem to fix and a repeater is an unnecessary crutch.
Silly question, but have you verified that the coax is actually connected to the back of the outlet plate? There's only a few things that could be wrong here, and they should all be simple to find and fix.
