Mud-hole
Member
- Jun 11, 2012
- Mount Holly, NC
Wondering if u need to increase air pressure in tires or decrease for muddy conditions
X2i have had the best luck running them as low as possible...but be careful to to run them so low that u knock them off the bead
Only other thing to consider, if you ain't got the umph from your motor to spin them fast enough to clean the mud out of the lugs, then air them up for it narrows the tire pattern (less sidewall) to contact the mud. Gives you less resistance for the spin cycle. If you ain't cleaning lugs, your tires become packed. There's only 1 may to navigate thick mud and that's the skinny pedal.
after I figure out why it wont let me advance edit.I've looked and there aren't many options for less than 12.5 wide on tires larger than 31".
