jaybird1ton
The Flats Offroad Park
- Sep 11, 2008
- Marion
We will be having our 2nd mudsling of the year on JUNE 20th @ The Flats Offroad Park in Marion N.C.The mudsling will start @ 4:00 on Saturday. The pit will be 200' and we did take the jumps out.
The park is located on I-40 @ exit 85. You can also use Google maps and search The Flats Marion NC for directions.
We hope that you will come and join us for some mud racing this year. Please share this with all your friends and lets get this out there. Questions call 828-442-5498 or 828-442-7932. More details to come!
Races will be every 3rd weekend and every race will be posted as an event on The Flats Offroad Park's face book page with info and rules.
Points system will be in place & final race will be for the ...championship!
Park will open @ 9am on race day.
Drivers meeting at 3:30. Race starts @ 4:00
Concessions will be served @ all races.
PAYOUTS WILL BE POSTED SOON!
2015 Race Schedule
May 30th
June 20th
July 11th
August 1st
August 22nd
September 12th
October 3rd
October 24th
TRACK RULES
1. No Alcohol beverages of any kind is allowed on the property.
2. No physical or verbal confrontations with track personnel will
be tolerated .
3. Racers and their pit crew will be responsible for the actions of their
members and guest. Any of the above rules (1&2) broken by
them will result in disqualification and loss of points for that
event. The individual will be escorted off premises and will be barred from
future events. ( No Refunds )
4. Helmets are required in all classes for driver and passengers.
5. All race vehicles will be required to have a hookup point or
driver will have to hook his own race vehicle to tow equipment.
6. Max. 5 MPH anywhere in pit area.
7. All drivers must attend drivers meeting before race.
8. All race vehicles from small block modified to mega truck classes must have a easy access kill switch within reach of driver. (this is not the master cutoff switch on rear of vehicle)
Rules:
4/6 CYL Street Class $25
4 CYL and 6 CYL street class will use the same rules as V8 street class.
V8 Street Class $25
Could pass NC inspection.
No gutting and must have dash, heater box, and all glass.
Can trim fenders for tire clearance. Body swaps OK. Must use full size frame and tires must line up w/ fenders +/- 3" No small V8 conversions.
Stock suspension. Lift kits allowed. Must have mufflers. Any DOT tire allowed. No cut tires.
No power adders. Diesels with factory turbo ok.
Can use 3 bolt-ons... example...carb, intake, headers or ignition. This class is intended for vehicles that are primarily street driven, have minimal modifications, and are street legal.
This class is intended for street vehicles, if you pull up to the line and your truck clearly sounds like it is modified for way more power you will be bumped to modified Street class per track official.
-Breakout rule, if you exceed the 2nd best of the field by 3 seconds you will be bumped to modified street class
Must have tow hook!
No motor over 460 cubic inches
MODIFIED STREET $40
Must be stock appearing and could pass NC inspection.
No gutting & must have dash and all glass.
small truck v8 conversions not allowed.
Body swaps allowed but must be done on full size frames . Tires must line up with fender wells. Can
Lift kits allowed. Any DOT tire allowed. No cut tires.
Must have mufflers.
No power adders. Diesels with factory turbo is ok.
Must run one carb and any bolt ons are allowed.
Must be a fully bodied truck. Fenders, hood, cab, and bed.
SMALL BLOCK MODIFIED $45
Any body type allowed. No fiberglass bodies. Fiberglass hood is allowed.
Bodies can be moved, narrowed or gutted. Small truck V8 swap is allowed.
401 cubic inches and down, bore & stroke can be changed.
Aftermarket blocks allowed but no aluminum blocks.
3 or 4 links w/ traction bars & sliders allowed. Coil overs allowed.
Single carb allowed. No fuel injection or dominator carbs.
Trans brake or 2 step not allowed.
Any transmission or transfer case or chain drive allowed.
Must use factory type frame. No tube frames.
Must have brakes.
Any vehicle without a top must have a minimum 4 point roll bar.
Must have 4 point harness & 2lb. extinguisher.
No power adders. If equipped w/ nitrous, bottle must be removed & solenoid unplugged.
Must have an easy access kill switch inside the cab that can be reached by driver.
BIG BLOCK MODIFIED $50
Any size engine allowed. After market blocks allowed. No aluminum blocks.
No rear engine. Driver must sit behind engine.
Any transmission, t case or chain drive allowed. Trans brake allowed.
Minimum 4 point roll cage & 4 point racing harness.
No sheet metal intake, only 1 dominator & no fuel injection
Must use factory type frame or rectangle frame. No round tube frame.
Any body is allowed with gutting/narrowing or fiberglass.
3 OR 4 links allowed. Sliders, traction bars & coil overs are allowed.
Must have a fuel cell and any fuel is allowed.
Must have F/R driveshaft loops.
Must have brakes.
Battery or fuel lines not allowed in cab.
Must have trans shield & flex plate shield.
Maximum wheelbase is 135"
No power adders. If equipped w/ nitrous, bottle must be removed and solenoid unplugged.
Must have a easy access kill switch inside the cab & 2lb. extinguisher.
PRO MOD CLASS $75
Any size engine allowed. Aluminum blocks allowed.
No rear engines. Driver must sit behind engine.
Any suspension allowed.
Stock or rectangle tubes allowed. No round tube frames.
Any body or fiberglass body allowed.
Must use D.O.T. tires. 54" max. No paddle tires. Cut tires allowed.
Single or dual carbs allowed. No fuel injection. Sheet metal intakes allowed.
No power adders allowed.
If equipped for nitrous, bottle must be removed and solenoid must be unplugged
Must have front/rear driveshaft loops & tranny & flex plate shield.
Must have brakes.
Any transmission and transfer case or chain drive is allowed.
Trans brake is allowed & any fuel is allowed.
Must have racing seats w/5 point harness and 2lb extinguisher.
Must have kill switch at rear of vehicle & easy access kill switch inside of cab.
No batteries or fuel lines inside of cab.
Must have brakes & 6 point minimum roll cage.
MEGA TRUCK CLASS $75
Must run a 2.5 ton style axles
V tread tires & DOT tires allowed. Any size
Roll cage is required. Fire extinguisher required.
Any motor allowed w/ any power adder.
Easy access kill switch is required in cab and outside cab.
Fire suit is recommended.
UNLIMITED CLASS $40
Anything is allowed in this class.
Nitrous is allowed! Anything goes!
Must have hard top or roll cage.
No batteries or fuel lines allowed in cab.
Must have brakes.
Must have 4 point harness or factory seatbelt.
This class could be split depending on horsepower.
Example 300hp buggy will not run against 1000hp mud truck.
Rules are subject to change for this class and will be discussed on race day w/ racers and tech guy.
2015 Race Schedule
May 30th
June 20th
July 11th
August 1st
August 22nd
September 12th
October 3rd
October 24th
TRACK RULES
be tolerated .
Rules:
V8 Street Class $25
Must have tow hook!
MODIFIED STREET $40
Must have mufflers.
Must have brakes.
Must have brakes.
PRO MOD CLASS $75
Must have brakes.
UNLIMITED CLASS $40
Must have brakes.
