jaybird1ton
The Flats Offroad Park
- Sep 11, 2008
- Marion
We will be having our first mudsling of the year on May 30th as part of our cancer benefit ride @ The Flats Offroad Park in Marion N.C.The mudsling will start @ 4:30 on Saturday. We do have a timing system in place and a scoreboard now! The pit will be 250' but we did take the jumps out.
The park is located on I-40 @ exit 85. You can also use Google maps and search The Flats Marion NC for directions.
We hope that you will come and join us for some mud racing this year. Please share this with all your friends and lets get this out there. Questions call 828-442-5498 or 828-442-7932. More details to come!
Races will be every 3rd weekend and every race will be posted as an event on The Flats Offroad Park's face ...book page with info and rules.
Points system will be in place & final race will be for the championship!
Park will open @ 9am on race day.
Drivers meeting at 3:30. Race starts @ 4:00
Concessions will be served @ all races.
2015 Mudsling Race Schedule
May 30th
June 20th (tentative date) May be changed to 27th.Will update ASAP!!
July 11th
August 1st
August 22nd
September 12th
October 3rd
October 24th
There will be 100% payouts to all classes! PLUS bonus money!
Rules:
4/6 CYL Street Class $15
Must be stock motor.
33" tires and under. No cut tires.
Lift kit is allowed. 4.5" max.
One bolt on is allowed. No power adders.
Factory adder is allowed.
Must pass NC inspection
Must have a tow hook.
V8 Street Class $15
4 CYL & 6 CYL Hot Street $20
4 CYL and 6 CYL hot street class will use the same rules as V8 hot street class.
V8 Hot Street Class $20
Must be stock appearing and could pass NC inspection.
No gutting and must have dash, heater box, and all glass.
Small truck V8 conversions not allowed.
Body swaps will be allowed but must be done on full size frames. Tires must line up with fender wells. Can trim fenders for tire clearance.
Lift kits allowed. Must have mufflers. Any DOT tire allowed. No cut tires.
No power adders. Diesels with factory turbo ok.
Can use three of these bolt-ons... carb, intake, headers or ignition.
No motor over 460 cubic inches.
MODIFIED STREET $25
No gutting & must have dash, heater box and all glass.
small truck v8 conversions not allowed.
Body swaps allowed but must be done on full size frames . Tires must line up with fender wells. Can
Lift kits allowed. Any DOT tire allowed. No cut tires.
Must have mufflers.
No power adders. Diesels with factory turbo is ok.
Must run one carb and any bolt ons are allowed.
Must be a fully bodied truck. Fenders, hood, cab, and bed.
SMALL BLOCK MODIFIED $30
Any body type allowed. No fiberglass bodies. Fiberglass hood is allowed.
Bodies can be moved, narrowed or gutted. Small truck V8 swap is allowed.
401 cubic inches and down, bore & stroke can be changed.
Aftermarket blocks allowed but no aluminum blocks.
3 or 4 links w/ traction bars & sliders allowed. Coil overs allowed.
Single carb allowed. No fuel injection or dominator carbs.
Trans brake or 2 step not allowed.
Any transmission or transfer case or chain drive allowed.
Must use factory type frame. No tube frames.
Must have brakes on 4 wheels.
Any vehicle without a top must have a minimum 4 point roll bar.
Must have 4 point harness & 2lb. extinguisher.
No power adders. If equipped w/ nitrous, bottle must be removed & solenoid unplugged.
Must have an easy access kill switch inside the cab that can be reached by driver.
BIG BLOCK MODIFIED $30
Any size engine allowed. After market blocks allowed. No aluminum blocks.
No rear engine. Driver must sit behind engine.
Any transmission, t case or chain drive allowed. Trans brake allowed.
Minimum 4 point roll cage & 4 point racing harness.
No sheet metal intake, only 1 dominator & no fuel injection
Must use factory type frame or rectangle frame. No round tube frame.
Any body is allowed with gutting/narrowing or fiberglass.
3 OR 4 links allowed. Sliders, traction bars & coil overs are allowed.
Must have a fuel cell and any fuel is allowed.
Must have F/R driveshaft loops.
Must have brakes.
Battery or fuel lines not allowed in cab.
Must have trans shield & flex plate shield.
Maximum wheelbase is 135"
No power adders. If equipped w/ nitrous, bottle must be removed and solenoid unplugged.
Must have a easy access kill switch inside the cab & 2lb. extinguisher.
PRO MOD CLASS $40
Any size engine allowed. Aluminum blocks allowed.
No rear engines. Driver must sit behind engine.
Any suspension allowed.
Stock or rectangle tubes allowed. No round tube frames.
Any body or fiberglass body allowed.
Must use D.O.T. tires. 54" max. No paddle tires. Cut tires allowed.
Single or dual carbs allowed. No fuel injection. Sheet metal intakes allowed.
No power adders allowed.
If equipped for nitrous, bottle must be removed and solenoid must be unplugged
Must have front/rear driveshaft loops & tranny & flex plate shield.
Any transmission and transfer case or chain drive is allowed.
Trans brake is allowed & any fuel is allowed.
Must have racing seats w/5 point harness and 2lb extinguisher.
Must have kill switch at rear of vehicle & easy access kill switch inside of cab.
No batteries or fuel lines inside of cab.
Must have brakes & 6 point minimum roll cage.
MEGA TRUCK CLASS
Must run a 2.5 ton style axles
V tread tires & DOT tires allowed. Any size
Roll cage is required. Fire extinguisher required.
Any motor allowed w/ any power adder.
Easy access kill switch is required in cab and outside cab.
Fire suit is recommended.
OPEN CLASS $30
Anything is allowed in this class.
Must have hard top or roll cage.
No batteries or fuel lines allowed in cab.
Must have brakes.
Must have 4 point harness or factory seatbelt.
This class could be split depending on horsepower.
Example 300hp buggy will not run against 800hp mud truck.
Rules are subject to change for this class and will be discussed on race day w/ racers and tech guy.
May 30th
July 11th
August 1st
August 22nd
September 12th
October 3rd
October 24th
Rules:
V8 Street Class $15
MODIFIED STREET $25
Must have mufflers.
Must have brakes.
PRO MOD CLASS $40
MEGA TRUCK CLASS
OPEN CLASS $30
Must have brakes.
