fishgutz
Active Member
- Oct 13, 2008
- Greensboro
My $0.02 summary on the subject of Dana 35 rear axles based on my own experience and the many D35 threads I have followed here. What I know now has been learned from knowledgeable people on this board and some very patient people back in NH and MA.
First, I would not have spent $1000 having a Detroit True Track and new 4.10 gears installed in my stock D35. The Dana 35 housing is not strong enough to reliably run anything bigger than 31” tires. The stress of 33’s twisted the axle just enough the shear bolt heads off the locker. The bolts heads just mangled up everything in the diff.
If I can find the old pictures I’ll post them.
If 31’s are you ever have planned, fine. But your first trip to Uwharrie will change your “to do list.” If it doesn’t, then you must have been traveling with H2’s.
There are a few affordable rear end upgrades. Ford 8.8 inch is probably the most popular. That is what I have now. Another mechanical master on this board recommends the Ford 9”.
If you score a Ford 8.8” with and LSD, don’t bother with the lunchbox locker. For a less $150 more you can get the Detroit locker and save time. You’ll eventually break the LSD carrier and have to get new locker anyway. When you read that the carrier is the weak link, take it from me, it is. It came out in two big pieces. Luckily the ring and pinion are still in great shape and don’t need to be replaced.
Had I done this from the start, I would have saved about $2000.
As for the front, I still have the Detroit True track I had installed back in 2003. Front upgrades occurred as needed after that. Vacuum diaphragm rust through so I installed Chromo axle shafts with 760X u-joints. When the tie rod ends went, I did a Rugged Ridge HD steering kit and Moog ball joints.
There are some nice Superior Axle/ locker packages that upgrade the front to 30 spline from the 27.
When I break something now, I look for the most affordable Right way of getting back on the road. Not the cheapest way. In my case, “cheap” often turns out to be more expensive.
If I decide I want to go bigger than 35’s that’s a whole other set of considerations and will have to wait until my kids are done with college.
If I can find the old pictures I’ll post them.If 31’s are you ever have planned, fine. But your first trip to Uwharrie will change your “to do list.” If it doesn’t, then you must have been traveling with H2’s.
