My $50 Generator
UncleWillie
Rarely serious.
Vale
Did a little work on the $50 generator today. It was on an ice cream truck and I bought it years ago with no idea if it worked or not because it had no fuel tank. Brought it home and it works.It has been tucked under the workbench in the shop for a long time. I am in the process of mounting it on a trailer so I can pull it behind the tractor.
Since it has no fuel tank starting it is interesting. The PO installed an electric fuel pump on it so I drop the fuel line in a gas can and hook the pump up to a battery. When fuel spurts out of the engines vacuum fuel pump ( usually about 3 seconds) disconnect the battery and pull the rope. Starts first time every time.
Had a friend weld an elbow and a piece of pipe to the booger welded pipe that was attached to the exhaust manifold and I dropped a Harley exhaust pipe ( that i got in a load of scrap) over the pipe and it is 50 times quieter.
:flipoff2: If you got a Harley muffler on a generator, you might be a Redneck!
You forgot the flapper on top to keep the water out....
I looked everywhere for a 1 1/4 muffler but couldn't find anything. Since I got that muffler for free it is a great deal. ANd yes I am a redneck. Just ask my wife.
Right now it has a light cover over it to keep the water out. A flapper will come later. I stuck that muffler on there today because it was so loud would couldn't stand to be in the yard with it.
