Need Advice - What is a good Rocker Slider for my 2012 JKU -- Want to replace the Plastic Side Step
Mike56
Member
Need Advice - What is a good Rocker Slider for my 2012 JKU -- Want to replace the Plastic Side Steps.
Looked at the Spiders but really cost too much. Was thinking of going to Smitty Built -- but wondering if other people can give me advice.
Want something that will give me some protection but will not break the bank.
Thanks in advance.
One good option for basic protection is to find Rubicon take offs, they are adiquite and will do the job and they can be readily had for cheap, you could add a set of ace sliders to them as well. The better in my opinioun are welded on style such as evo or lod. You can also contact the vendors here and they can make you a custom set for a price that might pleasantly surpise you. You didn't post up a location so I don't know where you are to suggest a local fabrication shop.
You are heading in the right direction in getting rocker protection, the 4 dr jk that tends to be a volnurable spot.
I am in the Durham area. I do off roading occasionally not a heavy off roader but want some protection when I do go Off Road.
You don't list where your from, but as said there are a lot of fab shops, on here, as well as "Sam24th" on here, of CTB. He's started building add on's from scratch, or build it to fit.[Charlotte]
