need help ASAP 98 grand cherokee transmission case
NoFlexRoom*98
mocksville nc
Hello Everyone
I am having difficulties with my zj. I have spent a lot of time replacing axles, motor Trans, tcase. So my tcase is a 242 J select Trac tcase. I cannot get it to go into 2wd. It seems like it only has 4 gears 4wd part time ,neutral, 4wd full time, and 4 lo. I have tried adjusting the shift linkage and every time I adjust it I loose 4 lo and neutral moves to 2wd spot. I have no clue what the problem is would someone please help. I'd greatly appreciate it.
Here's how to properly adjust that linkage:
Unhook the linkage
Manually shift the transfer case into low
Move the shifter to low
Adjust the linkage until it lines up
Good luck!
