NEED HELP FINDING A LEVELING KIT
THANKS BOWTIEMAN FOR THE HELP. IT'S GETTING CLOSER BUT I THINK THAT I'M GOING TO MAKE IT WORK WITH THE BRONCO SET-UP WHICH IS SIMILAR. NO ONE SEEMS TO HAVE ANYTHING SPECIFICALLY FOR THE 2WD 250 FOR 93 MODELS. THANKS AGAIN THOUGH.
Turn OFF the caps as requested please!
Personally I will not read any farther if it is all in caps.
LILGREENXJ
The reason folks mentioned turning the Caps lock off is ALL CAPS indicates you are "shouting"
This is called "Netiquette" and just an internet thing.
I understand it is easier to not bother to capitialize everything so if nothing else just don't bother to put ANYthing in capital letters instead?
[For futbal and ratlab, sometimes we have to tell them WHY we are asking them to turn off CAPLOCK, some folks are just starting to surf the net etc. Takes just as long to mention why as it does to beat em up! :) ]
Back to our usual programming...
Actually, for me it isn't just the "netiquette" thing, although that is annoying; actually it's just a lot harder to read things in all caps than sentence case. This is actually a proven phenomenon (at least for fluent readers).
I see all the caps and just don't want to bother with the effort.
i count 8 paragraphs in in which you bash this guy for using all caps, but only one post with help for his topic. YOU GUYS ARE D!CKS
IF I KNEW ANYTHING ABOUT 2WD FORDS I WOULD HELP EVEN IF IT ALL CAPS, BOLD, AND ITALICS OR WHATEVER THAT SLANTY TEXT IS CALLED. (CAPS LOCK JUST FOR FUN)
