GimmieBoost
Active Member
- Sep 7, 2008
- Lincolnton, NC
So it's Christmas Eve and of course something had to break.
Water was shooting out from the pressure relief valve on the water heater. I'm assuming the valve is toast. It's a gas heater and I noticed the heat was turned all the way up. If I turn down the heat and open the valve at the street halfway, will we be ok until Saturday? We're having Christmas here so we could really use running water.
Thanks a ton!
-Jesse
Water was shooting out from the pressure relief valve on the water heater. I'm assuming the valve is toast. It's a gas heater and I noticed the heat was turned all the way up. If I turn down the heat and open the valve at the street halfway, will we be ok until Saturday? We're having Christmas here so we could really use running water.Thanks a ton!
-Jesse
And yes if you read the box it is called a water heater.
