murphystoys
- Oct 6, 2005
- Greensboro NC
I bought a tach (sun pro super tach II) from a guy but no directions. Its got 4 wires a black, red, white, and green. If anyone could tell me where they go Id appreciate it.
Blkvoodoo said:Reciting this from memory, been a few years
Red, battery power (Use a fuse 7.5 amp is good)
Black, ground
White should be ignition trigger
Green illumination
hooking the trigger wire to the coil on the Toy could short the igniter, use the factory tach lead ( it has been done may times I am sure, but why risk it ? ) Tach was what $20? the igniter is over $100 or more if ya don't have a buddy with one somewhere
Kevin
jeepn-jason said:White to Parking Lights, can use any illuminated item in interior, ie.. radio, or switch or something.
Green to tach input from coil, or neg side of coil. IIRC u can also find this at the check conn. on Toys
Red to ign input, 12v when ign is on, you can find this at the ign. switch should be some heavy gauge wires use either the blk with yell tracer or blk with red tracer
Black goes to ground (duh) he he/
Pickup a cheap digital multi meter and you can do anything electrical in the car.
