Notes:Hall effect style sender, 16 pulse per revolution with pass-thru drive for cruise control. Adapts most GM and Chrysler transmissions with speedometer cable output. This sending unit is designed for use with Auto Meter speedometers, and will not work with OEM speedometers under any circumstances.
From my reading, the speedometer should read double your actual speed unless it is coming from the ECU and not straight off the sensor
