Need some 8.8 help
r1man
Mount Holly
I have a Ford 8.8 I want to install in my 91 Jeep YJ. I do not have the skill or tools necessary for the required welding of the new perches. Can anyone recommend a shop or an individual local to Mount Holly, NC that could help with or do the install? I also want to get a SYE installed and the front Dana 30 regeared at the same time. I dont mind paying someone to do it right, but I dont want to get raped in the labor charges either. Thanks in advance for any help.
8.8 is a great option. Everything with mine has been good except i screwed up the diff angle a bit easy enough fix.. but take some time and save some money if your getting work done figure your brake lines its cheaper for and easy for you to run and you can reuse your diff breather hose and if it came with limited slip make sure its working. These are just notes from those of us having done this good luck.
