need some advice
jeeperscreepers1
elgin sc
So I have a 96 xj aw4 trannie its fine till it warms up then starts to slip then goes into some kinda lymph mode or someing like that guess iam screwed hahaah found a 89 cherokee got an new rebuit trannine in it idk if its going to work is it tha same as what I have or what tha 89 has same tc as I got ......
if i remember correctly all xj's run with the aw4 4 speed automatic. and the majority of them ran the NP231 transfercase. you should be fine.
as the fluid warms up it loses viscosity. therefor the clutches will slip. sounds like the clutches are burned up or a a solenoid to a band is acting up.
