Aforbes704
- Sep 6, 2008
- Kannapolis
While I was trying to remove a broken exhaust stud I got a little impatient and broke the extractor off in the stud. Anyone one have any ideas on removing the stud now?
Not hanging out at allis the extractor hanging out at all?
Thanks I will try the center punch today and see if I can shatter it. The stud is broken off in the head not on a manifold trying not to remove it unless I have to.first, try using a center punch to shatter the remains of the extractor(it's very hard and brittle), if this doesn't work, remove the manifold, center drill with a smaller size, use another extractor from the backside if possible, sometimes heating it up will un-seize the threads, if not, then slowly work up in size to remove everything but the threads, then clean up the threads with a tap, if it still doesn't work, drill to size and use a long bolt from the back side of the flange-WARNING-the broken extractor is harder than any drill bit you own and will trash it
Where do buy it?<hush hush -- trade secret>apply kimbell midwast "torq cb"($10-15 per can.. you will never use PB Blaster or WD40 again.. its that good).. let soak 5-10 min.. take a washer/nut of appropriate diameter, hold it on the stud, apply welder, apply wrench while still hot.</trade secret>
That's the stuff.
