Need some info on H1s
andybritt2002
Chesapeake, Va
Hey guys, any one have any links or know of any good places that show a good how to for DIY on Recentering H1s? Im trying to do enough to fit on a d60 and 14bff for a k5. What would be 1 of the better places to purchase centers from ? Any info would be greatly appreciated. Also heard its possible to sawsal and grind the old centers out on ur own.
I have ran some with stock backspacing using (good quality) wheel spacer's and beat on them pretty hard with NO problems BUT if you want to recenter a set I have used some from www.greatlakeoffroad.com in the past. Also get a set of rock rings and that will not only strengthen the bead of the rim it will also protect the bolt's that hold the two rim pieces together. There are some companies selling pressed center's which drop in & I have not ever used. There is a set on here For Sale for $600.00
If you recenter make sure your new centers are beveled for the lugnuts or they will come loose after a while. Also when welding tack and recheck many time. Its really easy to get them off.
