Travs97
Member
- Sep 15, 2005
- poor side of Weddington
is there a way to lock my hellas on my bumper so no one gets a freebie
they are proud of those things. thanks everyoneridefast said:either tack the nut and bolt together or get some of these....
http://www.tuffyproducts.com/door/104.html
wbcarver said:Dang - those tuffy locks cost more than my lights !!
· Take a file or chisel to the threads and bung them up.
WHTTRASH said:what do you mean by "bung them up"?
wbcarver said:Score, abrade, damage, or otherwise make unusable.
I would have said "Bugger" them up, but I knew you were lurkin' around here somewhere and didn't want to get you all excited.
its the sleeve lock.......tuff stuffridefast said:green locktite?!
Travs97 said:they are proud of those things. thanks everyone
rockcity said:the green lock tight is a nooo
you want to be able to remove them later don't you???
then don't use the HD lock tight, its a pita when trying to remove bolts...
Travs97 said:well yes if they brake then i need to be able to take them off. so for 200+ lights then a 42$ for a lock is worth it.
and a strong right handAaron871 said:via 2 breaker bars or a grinder.
Travs97 said:and a strong right hand
