Exploderpilot said:
what makes them more dangerous than these garden stone retaining walls around the edge of shopping center parking lots.
Not trying to start a war but i have seen 4x4 timber walls used successfully in many places. They just used timbers running perpendicular to the wall back into the dirt and covering them with gravel and soil.
Those "garden stone walls" are engineered. This means somebody took into consideration the soil type, moisture content, height, slope above and below, amount of traffic, future planning, subterranian contures, and at least 20 other things that i dont want to confuse you with. They use geotextiles, or "grid" to tie it into the grade behind the walls. This grid is used, usually, every other course, compacted in with a plate tamp. This process is repeated til the wall is at the desired height.
The dead men timber walls you mention break down, decompose after a very short time. No they won't be so soft you can crumble it in your hand, but add thousands and thousands of pounds of pressure and a little bit of rot and that timber wall will blow out with enough force to blow timbers 50ft. We are designing a block wall for replacement a timber wall that did just that.
Then you add in the fact that there are landscapers that trust the timber walls, try to copy what they see, and build it the same way you describe.
With deadmen and screws and "dirt".
THAT WILL KILL PEOPLE.
Anyone can half-ass something to "make it work" even appearing to be "successful" what you are witnessing my friend is a time bomb.
Just trying to keep the public safe,
Shane
