So you swapped to a different MAF and larger injectors but didn't change the ECU tune? I don't know how that would work properly...
BOOO!!!Gonna take a step back from it for a little while. I'm just too busy and working till 8 every night stinks.
Looks like Lisa's ZJ will get to hit Harlan next week.
BOOO!!!
Yeah, I'm aware now. This engine is a solid 375-400 HP all day long and I can either run 30s or 24s but near their limit. I based that on numerous HP/Injector sizing charts online as well as advice from some racers.A guy I work with is a huge mustang guru, he said 30# injectors are too big for your engine.
So the injectors were the issue???
Do you not have the ability to scale the injectors via the ECM?
I'm sure that has occurred. Ill change the oil first of the week definitely. I'm going to pull the valve covers (those TFS fabbed ones won't seal for %&#@) and readjust the valves next week and do a bolt check on the converter.You change the oil since all this has happened? I'd figure the oil is definitely diluted.
