Deck tear down, day 1...
In preparation, I headed over to home depot yesterday with the trailer to pick up the wood, screws, new grinder, etc. Got a killer deal on a new Ryobi grinder. Opened box for $25. For 2.95, full 3 year replacement warranty. Wood, wanted pressure treated decking in 20ft length. No dice. Tried every lumber yard I could find in the book. 16 ft was the longest. So decided to get 10 footers and just split them that way. Pain in the butt, but couldn't think of anything else. So I was getting them from the lumber yard after dark last night. Bubba pulled them off and stuck them on the forklift. Couldn't see a thing, so I just counted. He was 4 boards short, so he brought back 4 more, but they were different size. I purchased 2x8s and then noticed that he put 2x10s on the trailer. He said, I'm going home, so just keep them.
This morning, got out and started taking all the screws out. There are 6 rows of 2 screws per board, 14 boards, all torx heads, rusted, and heads full of crap. So cordless drill wouldn't even move them. Started doing it by hand. After about 4 of them, went out to get the impact wrench. Then couldn't find a 1/2" to 3/8" drive adapter. Back to HD to get the adapter, don't have it, go to Stephen's hardware, don't have it, found one at the little Sear's outlet. Back home with the adapter, plugged it in to the impact and hooked up the air, nothing, impact barely spinning without a load. Oil, need oil....impact starts spinning, but no torque. What the crap...So head next door to the neighbors and borrow his impact. Still not getting it done. Must not be enough air, so hook up hose to neighbors big 100 gallon 10 hp compressor, finally got some movement. Still won't break them lose, gotta do that by hand with the breaker bar, but will run all those screws out.
Broke off about half of the screws. Had to cut the flat stock over the ends. Torx head socket breaks. Back to HD to swap. Girl charges me for a new one and again for the broken one.! Hey, just bought that last night and already paid for it and it says 'Guaranteed forever, so no charge.' 'Ain't never heard of that, I gotta call the manager...' so 20 min later, I get my replacement torx head and bought an extra one just so I don't have to go back to HD.
Finally get all the screws out and the rotten boards off. Had to break off about 50 screws and then grind down the remnants. With the boards off, I decided to inspect all the wiring and such while it was accessible. Found a ground that was broke for the running lights and fixed that. Wrapped a couple of spots with some electrical tape that looked like they needed it. Then I remembered I had purchased a couple of amber clearance lights to stick on the fenders so I could see the trailer at night. With all the lights recessed, and it being all black, you can't really see the trailer at night. So I dug out those two lights I bought like 4 years ago, drilled the holes into the fender and tapped into the wiring harness and wired them up finally. Drilled holes along one of the cross braces and zip tied the wire from the other side up and out of the way. Nice and bright now and I can see both fenders. Finally, something goes right.
Get all the boards off and you can see how they save money in making these trailers, not an once of paint underneath, only where you can see. Throw a couple of boards up for test fit. Because of using 2 ten footers, the seam didn't line up on the cross brace. So out to the shop to get some angle iron. None...back to HD, none. Over to Stephen's have some 2 inch by 4 ft only. Will have to do, back home. Figure out I can but weld the angle to one of the cross braces and make it work. Get ready to pull the trailer back to the shop and realize there is no way I can pull the truck and trailer back there without sinking it in the very wet yard. With all the rain yesterday and it was a river back there. So I pull the welder up to the driveway and have to wire in the right 220 plug in the garage to get juice for the welder. OK, got it covered now. Crap, no shield. Borrow my neighbors 1950s shield that is so dark you cannot even see the weld hardly. Weld in straight lines but 1/4 inch off the seam. Geez, I'm a moron, can't even weld today. Grind, weld, grind, weld, grind, weld, this is ridiculous. Finally get it done. Aimee yells out, leaving in 10 min!! Oh yeah, supposed to go out to dinner with another family to get some Greek food (was great food BTW, never really had Greek food before).
So hurry up and put all the tools in the garage, haul the welder back to the shop, pile all the rotten wood on the little trailer to haul to the dump, shower, shave, only 2 min late. Pick up some rattlecan rustoleum after dinner. Figure I should at least try to slow down the rust underneath a bit, so I'm going to get the girls to help me rattle can underneath.
Now that the hard part is done, I just need to trip about 2 inches off one of the 10 footers and I'll be set. I also picked up some 1inch angle iron. I'm going to leave a big enough gap between the wood and turn the 1 inch angle down along the edge on the top to help keep them down in the middle of the trailer.
So plan is to get the wood on and screwed down in the morning, load up the van, and take off for St. Louis. Maybe we can make it down to Asheville/Knoxville area and knock off a chunk of the trip and finish on Monday. Just ran out of time.
Man, I am beat. I always do stuff the hard way.....
Hope ya'll's projects went better than mine today!
Shannon
