- Mar 20, 2005
- Morganton NC
MR. GADGET said:So just so that I understand.
I have a motor that was running fine but was smoking a little and needed a valve job.
I can drop this to you and pick up rebuilt for 950 or so ready to drop in?
That sounds like a real good deal.
JOn
No, this is all you need to put it together. All the machine work. Parts ect Heads are complete though. He charges $500 to assemble over and above the cost of what I quoted. If you were to go this route you would receive:
Block with cam bearings and freeze plugs installed.
Your two heads
All your sheet metal cleaned.
Crank
Cam
Pistons and rods assembled
Kit with all gaskets, seals, rod and main bearings, push rods, lifters, assembly lube.
In other words the whole engine just not assembled. Sorry if it appeared to be otherwise
for those that know me.
