New Shaved 14 Bolt Rear Housing
Cperry
Durham, NC
https://eastcoastgearsupply.com/i-23993625-gm-14-bolt-rear-axle-30-spline-shaved.html
The ECGS 14 bolt features the highest quality parts available on the market.
The base price includes:
Brand New 14 Bolt Center Section with 4" x 1/2" (.500") DOM tubes. Housings come bare with chromoly spindles ONLY! TRUSS NOT INCLUDED!!
This axle is designed around a stock 14 bolt using upgraded parts, you can re-use your current brakes, hubs, shafts.
Choose your options below to outfit your axle the way you want it built. If you don't see an option listed feel free to contact us and we can provide an estimate.
Add Locker or Spool:
Select your choice between an ARB Air Locker, 30 Spline Spool or Yukon Grizzly Locker (Includes New Carrier)
Add Shafts:
Chromoly 30 Spline Axle Shafts
Differential Cover:
Full 2" shave cover (requires shaved ring & pinion) select below to have the bottom plate welded or shipped loose.
Select Gear Ratio:
We use the highest quality ring and pinions along with Timken bearings, this price also includes a solid pinion spacer. You must select a locker or spool for this option!
WMS
We have five popular options for wheel mounting surface (WMS). 63", 65", 67", 69", 72"
Availability: TYPICAL SHIP TIME IS 45-50 DAYS FROM DATE OF ORDER!!
Very nice!!!!!!
A few questions: Are these using a new casting, or are you machining standard housing down and adding a shave kit? Is the shave kit and cover available separate? No fill plug in the cover? Available to be built as a front axle?
We are using a new standard casting and shaving it. The shave kit is spec'd for us but is very similar to existing shave kits and is available separately. There is a fill plug in the side of the casting, so we are not currently building with one in the cover. These are available to be build as front axles, the 14 bolt front on our website should be updated soon to reflect the new tube diameter.
