New shocks and 1" spacer install... how much?
BigClay
Knower of useless ZJ things
Winston-Salem
Long story short, I have torn the tendon in my arm, so I can't really do this job myself.
If I already had the shocks and spacers; at a normal shop rate, how much do you think a shop would charge me to install all four shocks and four new 1" spacers on my 96 2500 Ram 4x4? $100, $200, $300, $400?
Clay, call me we can do it at my shop... If you can point, I can do!
Wheel spacers? Or coil spacers up front and a block in the rear?
If it is the Wheel spacers, I would expect roughly $80-120. If it is the Coil/block and shocks I would expect $240-$340 depending on if they are doing an alignment.
Coil spring spacers in fornt only, no blocks in the rear.
Way to step up Pebbles.
I'll do wheel spacers for 25$ all day. What a rip off
I assume you are talking just the wheel spacers.......I was including installing the 4 shocks and wheel spacers in the $80-120 estimate.
I would expect a shop to be around $250-300 for the front coil spring spacer install, 4 shocks install, and alignment.
