new to me trail rig
adam greene
morganton
im sure some of yall know this xj so let me know how good its built and all the info on it, i know it has a 9 inch rear and a hp44 long arm 3 link and 37 mtr on hummer beadlocks
I built it a while back. I did not cut any corners on it like some of the others I've seen. What all would you like to know. Heres the build thread.
I was a little upset when he got rid of it but I guess thats how it goes.
yea thanks it looked liked it was built real good. i was just wonderin what lockers it had and if they were stock axels and stuff. the guy i got it from didn really know all the details.
When he got rid of it it had an Aussie in the front and nitro cromos alloy USA joints. Rear was a full detroit with stock 31 spline shafts.
76 hp 44 With an Aussie Locker
~ late 70's 9"
PORC HD sye
4.88 gears
Low ratio carrier for the 44
Detroit for the 9"
760x spicer u-joints (hoping they'll hold for now)
Assorted Johnny Joints and Ballistic hiems
Ballistic fab link and coil brackets
RE HD Trac bar and bracket
5.5 RE coils & boomerang shackles
TNT unibody stiffeners
Warn hubs and other fun and expensive brakes, seals, ball joints, blah, blah $$$
ok the guy i got it from said the front had a detriot and the rear was a spool lol. but i know the front doesn unlock any turning so im guessin the aussie's gone lol. im hopin it will be a good rig it looks to be so far.
funny thing is that it was oringally from here, but i had to drive 600 miles to get it today and now its back to where it started life lol
another ? i have is how do you change the rear axel seal im not familur with the 9 inch? is it a full floting rear or what? also how do you unlock the hubs it has a cover over the hub and inside that it has a lock ring and such never seen anything like it before?
The rear is a semi float and it has a four blot flange out at the end of the axle. As for the front it has drive flanges instead of hubs. I had made a tool to pull off that cap and pull the flanges for the road. Just run a 1/2 inch bolt in where the plug is and it will in turn pull off the cap with out having to pry it off.
As far as the drive flanges go, there is really no need to ever pull one or unlock it for any reason as far as i'm concerned(unless someone actually swapped in a spool). That XJ and every jeep in recent history has had drive flanges from the factory.
As far as the front end acting like a spool, there is a good chance the aussie(or lockrite, or whatever) may need a rebuild. When they shear the pins there is a good chance of them locking up and essentially becoming a spool.
wanna sell it yet? seriously...
