adam greene
- Sep 9, 2008
- morganton
im new to the toyota world ive always had jeeps so anyways i have a 85 model questions i have is whats the best way to put power steering on it? and best way to make high steer or which kit is the best it has some kind of shackel reversal on the front with 4 or 5 inch lift springs and chevy springs in the rear. i wanna lower the whole truck so im thinking of putting stock springs in front and taking block out of rear. the stock steering is just so steep the bump steer is aweful and locked in the front hard to steer any help would be greatly appreciated.
if anyone has stock front springs and wanted lift springs id trade
I'd ditch the body lift, cut the tall ass front hanger out and weld in a normal one(i'm cheap so Id make your own). As for steering you will need and ifs box(86-95 4wd), I'd also pick up a steering box relocation kit, comes with the plates and sleeves. Springs I'd go ruf(rears of front) and Chevy 63s rear. Those should fit 35s fine, may have to add a small block (<2"). For front shocks you can use f250 stock towers and for shocks you might be able to use the rear shocks of an 02 f250/350 they are 13" travel.
