Nissan11
- Nov 29, 2005
- Marston, NC
If coolant was getting into the cylinder wouldnt there be evidence of it in the oil?
Not always, if its a tiny amount and depending on where its getting into the cylinders it can be consumed and exhausted in the combustion processIf coolant was getting into the cylinder wouldnt there be evidence of it in the oil?
If you ever have this problem again, look up restore and restore plus from a local fleet guard distributor. Need to be used separately, but combined they will clean anything out of a cooling systemDepending on what the orange is... maybe.
I helped a coworker flush an overheating S-blazer (4.3L) that had been mixed (Dexcool+green) and it was both jellied & crystallized. Took 3 flushes using CLR and the better part of an afternoon... to get it flushing clean...
buy american
If you aren't mechanically inclined enough to make a helpful suggestion please go play in the street somewhere else. Thanks.
I've used my laser thermometer many times. I usually get around 165-170 at the upper hose and 135 at the lower.
The intake shows about 170-180 when the truck is running about 190. Remember that I've got a mechanical gauge in the upper hose and the two factory sensors are in the intake. When I plug a scan tool into the OBD II port it matches the mechanical gauge exactly.
The dealer checked the head gasket by looking for bubbles and testing the coolant for hydrocarbons.
Not always...Shouldn't the truck at least be using coolant if it were the head gasket?
Not always...
Yeap if the gasket is blown between cylinders without having a spot that gets into a water jacket...So you are telling me that the head gasket could be bad without gasses getting into the coolant or coolant getting into the cylinders?
the radiator is hot, bottom is cold to the touch. So I'm thinking the thermostat isn't opening and causing the over heat. But why isn't it hot enough? Going to check the bleader valve next to the thermostat
if you had the timing marks aligned, it's in time. Did you remove the sprockets? It's got a little tiny copper pin to align the sprocket to cam and that's easy to screw up. If you had cam timing off, that whole bank would be low on power more than likely.Also I got a misfire code one in piston 5 during start up but only once right after I did the timing chain and a bank 2 timing advance error. But they haven't been back, could back 2 and bank 1 be off by hair s link In the timing causing over heating? Everything lined up right when I did the timing chain. So the colored links right spot tdc perfect and the sprockets and secondary were perfect also.
