Sorry, should have put more info. Axles are D60 front and 10.25 Sterling rear both from a Superduty. Front and rear are dual piston caliper disc brakes. Pads are almost new. He has a Wilwood proportioning valve for the rear that we opened all the way up. M/C is hydro-boost from mustang (for front and rear disc brakes) modified to work on his EB. We blead the M/C then blead starting farthurest first. Got clean fluid everywhere, and calipers ARE on the correct side. Pistons are moving and will clamp down on the calipers when you pump up the pedal, but if you pump the pedal up good and then go back 4-5 seconds later and press the pedal it will go all the way to the floor again. When you pump them up they have good pedal and it will stay good as long as you press on them. Anytime I have ever had air in the system you can pump them up and apply pressure and the pedal will slowly leak down, but not in this case. I am not sure is the Mustang M/C has enough volume for these big calipers
