BIGWOODY
- Mar 21, 2005
- Thomasville
Is it possible to have bad brake magnets...or weak ones anyway? My trailer brakes began to suck so I pulled it in the shop for some routine service. Tightened the bearings a bit, greased them all, fixed a couple of wiring issues, etc.. As for my brakes, I'll tell you what I have checked. I've got close to 12 volts at the power wire (on the truck) to activate the brakes. It drops to about 10.5 volts at the magnets in the wheel, seemed like a normal voltage drop to me and certainly enough to activate the brakes. After adjusting the shoes to where the wheel was dragging a bit , I backed them off just a touch. So when I activate the brake I can hear the magnets energize and start to grip the drum, but it's like the slip and don't fully engage the shoes. I can move the emergency lever on the brake controller and feel them starting to grab, but every other trailer I've had and did that it would lock the brakes( this one used to). The only strange thing I noticed when checking the drums and shoes were some grooves cut in the drum where the magnets grab, didn't see any sign of what caused them. It does make me wonder if the air gap in the grooves could be causing my poor braking, but I feel like I'm reaching with that diagnosis. A trailer expert I'm not , any help, ideas?...Greg
