no fire
jeepinfreak0226
Morganton
got a 87 yota not gettn fire changed coil, ignitor, pickup coil still nothing.and i have checked all the fuses.ran fine when i cut it off at work an when i got off to go home there was nothing. any ideas woild help.
Where are you from? I might be able to help
did you check the main fuses under the hood? They are real hard to tell if they are blown or not. Are you 100% sure its not the battery?
Did you pull the plug going to the dizzy and check the voltage there? Did you check the voltage going into and comming out of the coil?
Check the rotor button? Have seen them crack or come off and not let fire through.
Switch the two green plugs, I've seem people switch them if they are the round ones. (people being myself and I felt stupid).
I did the same damn thing one time....
