Webbinator
- Mar 20, 2005
- York, SC
There's been a problem on my '78 CJ7 258 that I've been trying to work out for some time now. The thing starts up and idles great. When I take it for a drive, I can go roughly 5 miles and it will start to lay down on me. It really gets bad if I'm going up a slight grade or just simply get on the gas. The power just goes and it sometimes will pop and buck. I've already tried a new coil, cap, and rotor. I'm running a full MSD ignition system also. I could probably spend a small fortune trying things to fix this. I'm borrowing another distributor this weekend to see what might happen. Just trying to eliminate anything that might be causing the problem. Anybody here got any suggestions on what could be causing this and what I could do to fix it. This jeep used to be really reliable until I quit using it for a DD. I guess things start to go when they just sit most of the time.
) thats why you are down on power...
86 chero 2.8 V6 also sorry to jump in, but it seems everyone is having around the same problem
