I'm looking at d44 dodge axle that has the vacuum disconnect as a donor axle just for the hub assembly. I need everythng from the balljoints out, ie rotor, hub, spindle etc. to go on my non vacuum disco axle. Is there any problem I would have a using the hub assembly from a vac disc to put on a non vac disc axle??? The guys said he already replaced the automatic locking hub w/ a manual hub. The donor vac disc axle is coming from an 89 ramcharger. The axle that needs the hub is an 81 dodge 1/2ton lp d44.
