GSRswapandslow
- Dec 20, 2005
- Taylorsville
so i picked up an 8.8 this weekend...drums (disk later), welded, warn diff cover guard, ruff stuff brakets to bolt into xj...
ok so i'm gonna toss this in one after noon...and a few things.
1. what u-bolts should i get? i looked all over online and most folks seem to have had them custom made.....not sure where to do that, so are there any i can just go to autozone or advance and pick up that'll for sure work?
2. brake line....guy said use a yj line, i don't have one....is there anyway to get away with my stock one? i have 4.5" of lift and it's fine on there right now.
3.there's a hole for, what i assume is, the stock distribution block for the rear brake lines....can i just put a bolt in here to plug it?
4. are the jeep and exploder studs the same size/thread/pitch? i was just gonna reuse my stock lug nuts if possible, but if i need to grab some i can.
5. axle didn't come with any e-brake cables....i have an auto so i have parking pawl....but should i look into getting a set anyways when i go to do the brake swap to disk?
i think that's it...i'm sure if i walked outside and rolled it under the jeep and bolted it up, i'd have my answers....but getting home when it's dark, having to work on grass, and being tired from work doesn't help (takes all my effort to hold the desk and keyboard down for 8 hours straight!...minus my lunch hour) but...i figured i'd just start a thread as a semi-motivation/check list thing.
