NP-200 Tcase
Nissan T100 t-case found in the 720 is a divorced case that is clocked down in a stock application. Would drop your outputs 6-7".
So if I run a np200 tcase I'll need to have 3 driveshafts custom made, one from my Toyota 4wd tranny to the np200, one from the np200 to the rear axle, and one from the np200 to the front axle? Correct???
You will have to use a 2wd transmission.
Duane
One other thing to think about is the NP200 is not the best designed t-case for modern vehicles. They weren't originally designed to go over 50mph, anything faster and they begin to overheat. The overheating can be overcome by fabricating an oil cooler, fan, and circulation pump but it's way too much work overall especially when you consider the other alternatives listed in this thread. Also remember the low range is only 1.96:1 and there isn't an easy way to run a doubler. If you ever want to make a super slow crawler, you will have to swap cases again.
