ive got a friend needing help diagnosing some noise/vibration. He believes it is coming from his 205 case. Looking for a reputable shop between Mt Airy and Kernersville NC. @Oliver's @John Smith
My first guess would be rear pinion, if happening when coasting.From the owner..
“68 GMC with 6" spring lift, Dodge NV4500 with GM input and Dodge NP205. Has about 5,000 highway miles and it had a ceased rear u-joint in the 1st 500 miles.
It does it [vibrates] all the time in 4H and really bad on the coast side of the gears.
In 2H it really only does it above 60 MPH on the coast side of the gear.
Just as a thought, I would try to put a spacer under the transmission 1 degree isn't very optimum for pinion angle did you like the way I put that big word in there John Smith lol. But seriously trans spacer would be the easiest place to start if it got worse or better that would give you some direction. Vibration in 4 hi is prolly your front shaft till your problem is fixed I would remove front shaft to take it out of the mix. You mentioned truck was lifted with springs so im going to assume no lift blocks in rear? are there shims on springs? is truck short bed or long bed? lots of varibles to fixing vibration. Good luck with it, make sure and post results please.I'm the friend in King that strange1 is talking about. The driveshaft angle out of the xfer case is about 12* and 11* measured at the rear pinion. The tranny and xfer case is only about an inch longer than the SM465/205 that was taken out with the same lift, wheels and tires and there was never any driveline vibrations or odd sounds with that setup at up to 100 mph.
That being said, the vibration, growl, rattle seemed to be coming from the transmission or transfer case. The issue was only noticeable above 60 mph in 2H until I drove it in the snow in 4H in early December and the same issue was now amplified greatly and it was obvious it was coming from the 205.
I think I might just contact Melvin Beasly that was suggested above and have him pull it out and take a look.
Thanks for the help.
