np231j sye eliminator.
jeepyjman
Concord
do I need any special tools? I orderded my kit but it will not be here until after I am at work friday so I dont know if I need to brring any tools from work. I know they have good instructions with the kit I just have not received it yet. if it helps i got the jb conversions kit.
Decent sized set of snap ring pliers, 15 mm socket, 10mm 12pt socket, 13mm socket, small flat blade screw driver, 1 1/8" socket and that should about do it.
Like ^ said, its pretty straightforward. Give me a call if you have any questions, you've got the number.
Ditto on the GOOD snap ring pliers. Will save you a lot of bad words.
Planning on starting my sye after I get back from the flats...and I've seen a lot about needing a good snap ring pliers...any suggestions on what to get? Or where
