3Sight
- Jun 28, 2006
- Raleigh, NC
Well, I'm most of the way through fitting my NV4500, an Atlas II under the frame rails so I can add a flat skid plate. I'm building the skid from 1/4 plate with angle on the edges.
I first tried an old bar from a high lift as my cross member, but it bend as soon as I installed it so I scraped it all and started over. I also was getting binding on the rear drive shaft so I added adjustable control arms on the rear.
As I adjusted the pinion on the D44 the shocks hit, so I created new shock mounts out of the 2x2 square tube I bought for the new cross mount.
I made mounts for the cross member out of extra 4x4 tube I had.
I got the crossmember in. Each side has 2, 1/4 bolts (grade 5). I drilled 3 holes in the mounts, but 2 seems pretty good right now. I might weld the edges as well, but not sure I need to do it. The cross member has 3" poly mounts welded to each end with 1/4 grade 8 bolts going into the mounts.
But the cat is stuck between the crossmember and the body.
I also had to re-weld my shifter as it was hitting the dash.
That's where I'm at now, hopefully I'll move the cat in the next day or two, I'm picking up some 3" springs on Friday (replacing my 2 1/2" old spring, including one broken rear). I'll finish drilling the flat skid today and might test fit as well. More photos soon.
