HANO
meh.
- Sep 16, 2006
- Myrtle Beach
I have an '01 TJ with a Dana 44 in the rear.
I have tried to get all the stopping power I can out of my rear drums, to little or no avail.
The TJ has a satisfactory bite on the front, but the rears just don't like to hold (new shoes, good drums). Everything has been adjusted correctly. The e-brake holds well, everything looks to be in tip-top shape.
I was looking at going to disc either through Tera's conversion or the Zj junkyard swap....
But before that, what would it hurt to either pull the O-ring completely from the proportioning valve, or say use one from a ZJ with disc or a Rubicon? ( A common mod for those with newly added disc brakes )
Faster brake wear, high heat, premature lockup, blown wheel cylinders, or all of the above?
The jeep is trailered, driven on the road occasionally, and I do not care if I have to change rear shoes every year......
Whats the deal with sending more or perhaps too much pressure to the drums?
Would an adjustable valve serve me better...?
2001 TJ 4.0, auto, 4.10s, 35's
J.R.
J.R.
